1987 oil filter brand/color
  • S4George
  • S4George's Avatar Topic Author
  • Offline
  • Junior Member
  • Junior Member
12 Jun 2016 14:03 #19063 by S4George
1987 oil filter brand/color was created by S4George
What brand of oil filter did Porsche use for MY 87 when they rolled out? Also, were they Black or Red?
16 Jun 2016 21:05 #19067 by jmwise
Replied by jmwise on topic 1987 oil filter brand/color
I can find no reference to the brand or color of oil filter originally fitted to your 87S4 in either the Owner's Manual, the Technical Specifications booklet (which goes into MUCH greater detail than the owner's manual) or PET. However, reliable sources have indicated it was a Purolator.
The good news, though, is Porsche Classic Genuine Parts has re-introduced the "original" oil filter, indeed a Purolator that is red in color. The current part number appears to be 928 107 201 07, although I've seen what's believed to be a truly original filter bearing 928 107 201 03. More info here: rennlist.com/forums/928-forum/844705-por...-red-oil-filter.html and here rennlist.com/forums/928-forum/378250-oil...nds-for-a-928-a.html
Should be available through Porsche Classic Genuine Parts channels, or just call Roger at 928sRUs (817) 430-2688
HTH!
Jarrod Wise
90GT
928 Owners Club President
928 Registry Chair
The following user(s) said Thank You: S4George
  • S4George
  • Offline
  • Junior Member
  • Junior Member
17 Jun 2016 14:49 #19069 by S4George
Replied by S4George on topic 1987 oil filter brand/color
Thank you very much Jarrod. Huge help!
30 Jun 2016 14:59 - 30 Jun 2016 15:15 #19095 by Kiln_Red
Replied by Kiln_Red on topic 1987 oil filter brand/color
The original filter is a Mahle. Not sure what color they were then, bit the Mahle filters are all black for the 928.
Edit: Correction! The very first filter that came with your MY87 may have very well been a red Purolator, as Jarrod said.
Last edit: 30 Jun 2016 15:15 by Kiln_Red.
  • S4George
  • Offline
  • Junior Member
  • Junior Member
01 Jul 2016 16:09 #19105 by S4George
Thanks KR. I went with a 92810720107
