1982 Fuel Line Replacement
5 years 11 months ago #21619
by Bodner
1982 Fuel Line Replacement was created by Bodner
I’m planning to change out my rubber fuel lines this winter. When doing my due diligence by researching the issue, I see a lot of disagreement as to type of hose, clamps or no clamps (assuming that replacement hoses are still not available). Is there any consensus among the members as to a preferred method of fuel line replacement? Thank you
5 years 11 months ago #21620
by joejabq
Replied by joejabq on topic 1982 Fuel Line Replacement
Roger at 928sRus has a fuel line replacement kit with all the pieces that you need.
5 years 11 months ago #21621
by Bodner
Replied by Bodner on topic 1982 Fuel Line Replacement
Thank you, joejabq. Yes, I’ve seen Roger quoted on this and many other topics. I will follow up with him
5 years 11 months ago - 5 years 11 months ago #21624
by joejabq
Yeah, getting the 928sRUs fuel line kit is the easiest thing to do. You’ll be assured of getting the right type of hose and clamps. The only hard part was the one connection between the engine and the firewall. I couldn’t get enough room to use wrenches to take the connector off so I had to cut the old hose clamp off at the connector with a dremel tool and then just clamping the new hose to the connector. It’s a satisfying project. Good Luck!
Joe
Joe
Last edit: 5 years 11 months ago by joejabq.
5 years 10 months ago #21638
by Bodner
I am going to get everything from Roger. One final question: what is the best method to relieve the fuel pressure prior to removing the fuel lines? Thank you,
5 years 10 months ago #21639
by joejabq
I'm not sure what the best way is. Maybe others will chime in on how they do it. It's been a while since I worked on the fuel lines, but if you wait overnight from the last time you ran the engine, the pressure should have decreased and the engine will be cool/cold. Then you can slowly crack open where the fuel line that comes into the engine. I'm only familiar with a '79, which is a straight CIS (KJet system). I can't remember if it had changed for the '82's .
I always fret when I have the fuel system open. Be sure that you have a plan for how you want to handle the gas in tank. Of course, disconnect the battery.
Just be very methodical... Step-by-step... and you'll be fine.
Bodner wrote: I am going to get everything from Roger. One final question: what is the best method to relieve the fuel pressure prior to removing the fuel lines? Thank you,
