Parking Brake Won't Release
18 Apr 2010 14:26 #214 by bstevens
My parking brake is pulled all the way up. The rear brakes are holding as they should. I am not able to get it to release. Any suggestions out there. Thanks.
18 Apr 2010 15:24 #215 by srshaw3
Replied by srshaw3 on topic Parking Brake Won't Release
Not sure what you are asking. Are you suggesting your parking brake can not be released? Just a data point but the parking brakes are drum brakes inside the rear axle, they are separate from the rear disc brakes you use when driving.
18 Apr 2010 18:53 #216 by bstevens
Parking brake lever is stuck in the up position. I am not able to get it to release. Thanks for the reply.
18 Apr 2010 19:00 #218 by srshaw3
Perhaps if you get at the mechanical workings you can get it to release. Here is a link to a tip on adjusting it, perhaps you will find a way to release it while you are in there: nichols.nu/tip468.htm
18 Apr 2010 19:06 #219 by bstevens
Thank you 928racer. I'll try that.
