1989 S4 4-spoke wheel with 30mm spacer
11 years 5 months ago #18314
by jverdura
1989 S4 4-spoke wheel with 30mm spacer was created by jverdura
My 1989 S4 steering wheel has a 30mm built-in spacer (option code M018 Sport Steering Wheel with elevated hub ~30mm) that, for my build, makes for a very awkward driving position, I like the wheel a little further forward. I know some people prefer the closer rearward position, so if you prefer the latter, I propose a trade.
Do you have a wheel without the 30mm spacer and would prefer one with it, let's swap!
11 years 5 months ago #18316
by martinss
Replied by martinss on topic 1989 S4 4-spoke wheel with 30mm spacer
I have heard about the spacer but never seen one. From your comment it sounds like it is integrated in the wheel so you need to swap wheel and spacer together?
11 years 5 months ago - 11 years 5 months ago #18317
by billvvSU
Replied by billvvSU on topic 1989 S4 4-spoke wheel with 30mm spacer
The spacer also raises the steering wheel somewhat, so if you need the legroom you might hold on to it. Perhaps borrow a stock wheel and try it. Hook up with the NorCal Region this weekend at '
Sharks in the Park
Or Mark Anderson (928 International) can sell you a used one and if you like it you can then have it recovered by Paul Champagne or Ron Budd.
Last edit: 11 years 5 months ago by billvvSU.
