OK, I need help
16 years 5 days ago #1998 by 928mac
OK, I need help was created by 928mac
I want everyone to chime in one at a time with what I should do next.
By that I mean, one person says disconnect the battery and I respond done.
The next person tells me step two.
I am overwhelmed because I have to pull the engine, top end refresh with new head gaskets. Replace all fuel and vac lines. remove all electrical from engine to ez and not so ez computer and replace them and wireing with a Tec-4 ECM.
Flush brake system and replace fluid (same thing)
Install new line loc system for brakes
Replace heater blower resistor.
Evac test and repair AC so I don't have to sweat my balls off this year
Finish the stereo install that was never completed and install the GPS, alarm and back-up camera
install new clem clamp, new pktentioner and remove Torque Tube and inspect bearings.
Drain, remove pan/cover for trans and diff and inspect
Inspect and repair sunroof (poss cables seized)
If i have time I should go through the window motors.
Oh ya I need new tires all around and I need to align it (no alignment pads yet) Note: phone Mac tools. order Tires
Remove pass seat and repair (stuck full back and down)
Remove clean all grounds
Remove dash and chase down and repair all loose connections
install new shifter Tee handle and wire in shifter switch to it.
ILL add things that I forgot later
16 years 5 days ago #1999 by Kiln_Red
Replied by Kiln_Red on topic OK, I need help
That's a lot to accomplish in just one winter, Brad. Have you already resolved your fuel leak? I would tackle that first. After that I would pull the engine. It's not too bad to do as I said before. Once out, I would go ahead and fit the new fuel lines. Then the next step seems obvious. Tear down, replace gaskets and install PKtensioner. After reassembly, replace everything on top. After that, I have no idea because I no absolutely nothing about your new fuel system but installing that would be my next focus as well as reinstalling the engine.
I wouldn't worry about the torque tube if there are no obvious issues. That's just me. Don't overwhelm yourself. Simply take it all step by step. Just focus yourself to one specific duty at a time. Most importantly, take your time. Don't let yourself feel disappointed if you haven't gotten everything done by the first of spring or whenever. Realize that whenever you have it all done it will definitely have been worth the work and wait.
16 years 5 days ago #2001 by 928mac
Replied by 928mac on topic OK, I need help
The main fuel leak is at the tank at that valve/pump that threads into the tank.
which reminds me that I need to order that and the fuel dampener under the hood. Its been caped since I got the car.
16 years 5 days ago #2007 by Kiln_Red
Well, I am happy to have reminded you of something. :)
Step 2: Remove engine ground strap to body. Step 3: Undo harness clamp at cross member. Get those two out of the way now so there is no fear of forgetting later. I guess go ahead and remove engine harness from hot post too, while you're at it. Then remove the entire fuel injection harness and ECU. Remove exhaust and o2 sensor.
16 years 5 days ago #2013 by 928mac
OK that is a good start list Austin.
First ILL disconnect the Battery and let you know as I complete the above. Company today but the guys and I might get started on it after the beer starts to flow. :D
16 years 5 days ago #2020 by Kiln_Red
Off topic, but what is your beverage of choice? :D
