Engine removal
27 Jan 2012 11:32 #7934 by denhamfly
Engine removal was created by denhamfly
I am looking at the picture in the shop manual to hook up the host to remove my engine, and I can’t see were they want you to hook up the host anyone know a good spot to hook it? pictures of removal: s1125.photobucket.com/albums/l581/denhamfly/#!cpZZ1QQtppZZ20
27 Jan 2012 11:40 #7935 by srshaw3
Replied by srshaw3 on topic Engine removal
If they haven't been removed, there is a metal loop bracket in the left front and another in the right rear of your motor to use. If you don't have them, you can buy them and put them on. I don't have an '85 here, but I can probably get you a photo of the ones in my GT which are about the same as I recall.
You may know, but just in case, the 928 motor is really heavy, so use a hoist capable of at least 1/2 ton and similarly an engine stand.
27 Jan 2012 12:08 #7936 by 928mac
Replied by 928mac on topic Engine removal
Or if you are sitting in the car it is the right/pass front and left/drivers rear.
I could not find the drivers rear, not even with both hands, ha ha ha
Mine was missing.
You can buy them or make one.
When I set mine back in, I used the intake bolts but 2 bolts are not enough, you need 4 points.
27 Jan 2012 12:13 #7937 by denhamfly
Replied by denhamfly on topic Engine removal
I don't see any hooks where do they bolt to if i make them Thanks!
27 Jan 2012 13:11 #7938 by srshaw3
This photo shows what the back one should look like. I don't think you are going to be able to bolt it on with the motor in the car....
I think the front looks similar on your car, on my GT I think it is a more centralized bracket that looks different.
Attached files [img]media/attachments/8110=899-928_motor.jpg[/img]
27 Jan 2012 13:13 #7939 by srshaw3
I was able to use the two points with an engine leveler.
27 Jan 2012 16:13 #7940 by 928mac
I did too Stan but as far as strength goes, I could not recommend it on the site incase a bolt lets go and someone gets hurt.
Here is a pic of mine, but next time I will use 2 equal length chains
27 Jan 2012 16:17 #7941 by denhamfly
I have it hook up to 4 points, don't worry it something wrong I will be in rehab for alcohol poisoning.
27 Jan 2012 16:23 #7942 by srshaw3
I don't see an engine leveler in that picture, and am pretty sure mine has two chains. More like this
Attached files [img]media/attachments/8114=900-928_motor.leveler.jpg[/img]
27 Jan 2012 17:55 #7943 by 928mac
That is exactly what I wanted Stan. I saw one and went back the next day and they were out and on back order. I still dont see that they brought more in so i may have to order it before I pull the engine again. I wish I would have had time this year but the way things are going ILL be luck to get the inside stuff done and the alignment.
27 Jan 2012 18:17 #7944 by denhamfly
It is out an pictures to come, I going get drunk!!!!!!!!!!!!!
27 Jan 2012 18:38 #7945 by 928mac
ha ha ha see, its not that hard.
but its twice the work to get it in and running again.
27 Jan 2012 22:25 #7952 by denhamfly
Thanks Brad for letting me know my future!
28 Jan 2012 13:04 #7957 by denhamfly
pictures are up. i will be asking advice shortly
28 Jan 2012 14:12 #7960 by 928mac
Stay Drunk ha ha ha :D
29 Jan 2012 23:29 #7979 by Kiln_Red
Replied by Kiln_Red on topic Engine removal
Truer words have never been spoken.
31 Jan 2012 13:09 #8017 by srshaw3
If you are looking for a removal loop, I have a new 928 1131 173 02, still in the bag :)
