Engine does not want to start after rebuild-ideas
13 years 5 months ago #15122 by xstepson
I put a harmonic balancer on backwards once.(letters were upside down when looking from the front of the car) I had compression, I had spark, and I had fuel. I had all the right things but just not at the right time. I swapped the balancer around and the car started right up.
If I understand correctly, you used an 84 Euro block but your original '80 fueling?
You got a wiring harness from Motorsports. Is it the correct one for the CIS?
What distributor are you using? '84 Euro is LH which uses a CPS to time ignition.
I'm sure you know all this, but I'm just trying to help us brainstorm a solution.
13 years 5 months ago #15130 by Jdoran
Again - John thanks for any insight. I appreciate your time.
I made sure the harmonic was correct - even validated in the Porsche manuals - I got very excited when I though I had put it in wrong - crap - I did it correctly.
Using the CIS from 80 - wiring harness for an 80. I used the 84 lower end but used my 80 oil pan, all bolt-ons' came from my 80. I am really quite perplexed. I even used a compression tester to make sure that the TDC was on the compression cycle - unfortunately it was. I am using the distributor from the 80 since the heads and cams are from the 80. I turned the motor two rotations to validate that the timing/cams/rotor were all in sync - again it looked correct.
My next idea is to put the old/OEM starter back on. Just thinking that there may be some electrical issues with running. There was some notes about issues in the instructions from 928 motorsports.
I'm thinking a 9mm to the body will get it's attention.
Again - Thanks for you time and all brainstorming is greatly appreciated
13 years 5 months ago #15131 by the flying scotsman
Jordan if you do have compression fuel and spark then its a timing issue either with the when the spark arrives or fuel is injected.
If possible can you can back to the original harness and all other components even just a temp hookup to see if it will fire up.
13 years 5 months ago #15132 by Jdoran
I wish I could but the old harness literally is falling apart. I have been going over everything again and may have found something. I was checking the plugs and found I was shipped 1985 on plugs. Got the right ones but then rechecked the spark with the plug out. It looked really weak and did not have the usual snap sound. I have checked the voltage on both sides of the coil. I have 3 on the 1 side and 5v on the 15 side. I would believe that there should be 12 on either side but I cannot find any reference as to what it should be. In my domestics I look for 12 on the positive side of the coil.
Any ideas as to what could be causing this?
13 years 5 months ago #15134 by denhamfly
Check the sensor that that gives the position of the flywheel for the timing. I have the same problem the sensor was good but the ring on my flywheel had slipped had to line the ring back up and put a small tack weld on it to keep it in place. Finding that drove me crazy and about 10 Porsche mechanics. I also spent 3 thousand dollars by parts that i did not need. Good luck!!!!
13 years 5 months ago #15135 by the flying scotsman
Im not that familiar with the older models if they were fitted with a CPS (Crank position sensor)?.........if so was it changed?
