Backup lights not working
10 years 3 months ago #18997 by BSGD@928s
OK I looked again for the 2 prong female reverse switch on the transmission and still cannot find it. Would it be behind a plate that needs removed? I reached on top of the transmission and still cannot find anything the only plug I can find is a long boot with one single connector in it next to the transmission reservoir.. I appreciate any help because this has really stumped me I have power at the fuse and relay ( swapped relays to be sure ) but nothing back to connector in rear hatch. And the selector switch seems to be working because it won’t start out of park or neutral. Should there be power to that switch because I tested with ignition on and found nothing. I also see two wires going into the connector in the hatch one solid blue and one blue and black anyone know why there are two wires? Thanks
