Anti-Lock Warning Comes and Goes
- timberhollow9310
15 years 11 months ago #2318
by timberhollow9310
Anti-Lock Warning Comes and Goes was created by timberhollow9310
Here is an interesting one. From time to time the Anti-Lock brake warning light will come on (along w/center console master warning). I can turn off the master warning, but not the Anit-Lock warning.
If I put on the emergency brake and then release it (while vehicle is stopped) the Anti-Lock warning goes away.
Sometimes it will not appear for weeks, then start showing up regularly.
I don't see a Relay (unless I missed it) for this function. Anyone have a thought on this one?
Thanks in advance.
Ed Boudreau
Dallas
'87 928S4
Thanks in advance.
Ed Boudreau
Dallas
'87 928S4
15 years 11 months ago #2319
Replied by pcar928fan on topic Anti-Lock Warning Comes and Goes
Hope Sean and Roger are reading this and can chime in... I have never had that problem *knocking on wood* with my S4....
15 years 11 months ago #2320
Replied by srshaw3 on topic Anti-Lock Warning Comes and Goes
I presume you know the parking brake is a separate system from the disc brakes.
I suppose it could be an electrical connection that they have in common, so perhaps tracing the wires for the sensors to some common connector.
I would check the rear abs sensor, perhaps you have a poor connection that the parking brake helps clear temporarily.
- timberhollow9310
15 years 11 months ago #2321
by timberhollow9310
Right I knew about the sep. systems. Here is what I found on an earlier thread....
___________________________________________________________
porsche928forums.com/viewtopic.php?f=5&t=630
sharkythesharkdogg wrote:
All right. After some brainstorming and talking with other people I came up with a method of testing the ABS speed sensors that doesn't involve the ABS tester. (No local dealerships have it, no other Porsche specialists have it. Even if the dealerships had one it would cost $120 bucks to get it diagnosed. Lame.)
I figured since spinning the brake rotor through the magnetic field of the ABS speed sensors produces a small amount of power (like a D/C generator) that I could read it with a volt meter. So I unplugged the sensors, spun the wheels, and read the minuscule amount of voltage produced. 3 of the 4 produced voltage. The 4th produced no readable amount. Not a bit. To me that's a good indication there's a break in continuity and that the sensor is bad.
The sensors are over 200 a piece, though. The price we pay for superior German engineering
Replied by timberhollow9310 on topic Anti-Lock Warning Comes and Goes
Stan.Shaw@Excell.Net;2375 wrote: I presume you know the parking brake is a separate system from the disc brakes.
15 years 11 months ago #2328
Replied by 928mac on topic Anti-Lock Warning Comes and Goes
Good job on the diagnostic Ed.
You can check those or any (hall sensors) by checking the resistance but its nice to have the know correct Ohms/resistance to compare it to.
And yes, spinning a reluctor wheel or in this case the rotor will induce voltage into the sensor that as you have found out is a very quick way to check just by checking voltage as you spin the wheel.
I would then check the sensor for the correct clearance (compared to the others) For play in that bearing, and debree or metal fillings stuck to the magnet
Good luck, nice job and hope its an easy repair.
15 years 11 months ago #2355
by SeanR
Replied by SeanR on topic Anti-Lock Warning Comes and Goes
Just me, but I would start by pulling all of the ABS sensors and cleaning them. They are semi-magnetic and will get gummed up after time. All it takes is pulling the wheels are an allen key, then some cleaner.
If that that does not clear it up, then you are looking at an electrical diagnosis for the issue.
