Dead Batteries
16 years 6 months ago #305 by bstevens
Dead Batteries was created by bstevens
Suggestions from all. I have a 1991 928 GT. I am having problems keeping the battery charged. I have replaced it twice. I'll install a new one, will start just fine and after about 2 days it will have a bad cell. I have everything turned off. Lights, inside and outside etc. Haven't even been using car alarm. I would appreciate any suggestions. Thanks
16 years 6 months ago #306 by srshaw3
Replied by srshaw3 on topic Dead Batteries
Electrical drains are all too common in 928s.
I have heard of people simply cleaning electrical grounds to resolve issues, to people removing the fuse/relay panel to eliminate all corrosion there to resolve issues.
Greg's site has some tips nichols.nu/tip800.htm
I am presuming you are not leaving a light on, or something simple like that.
16 years 6 months ago #309 by bstevens
Replied by bstevens on topic Dead Batteries
Thanks for the info. Everything is turned off. I'll ck grounds etc. Thank you.
16 years 6 months ago #310 by Kiln_Red
Replied by Kiln_Red on topic Dead Batteries
928racer;330 wrote: Electrical drains are all too common in 928s.
You can say that again. I've just recently developed one on my car. Haven't had the time to chase it down yet. That's the bad part of using the 928 as a daily driver, but hey, I have no other options 'til I rebuild the engine in my truck. Though the drain is only about 850 milliamps, if ignored, it will definitely kill the battery.
For now, I'm just disconnecting the battery by way of the wing nut on the battery ground strap when I know I'm not going to be driving for a little while.
16 years 6 months ago #311 by 928mac
Replied by 928mac on topic Dead Batteries
KilnRed;334 wrote: You can say that again. I've just recently developed one on my car. Haven't had the time to chase it down yet. That's the bad part of using the 928 as a daily driver, but hey, I have no other options 'til I rebuild the engine in my truck. Though the drain is only about 86 hundredths of an amp, if ignored, it will definitely kill the battery.
Ya guys, 350 milliamps will kill the battery in a week so 850 ml is way to much.
The way to check is to disable the passenger side door switch by unplugging it so that you can pull fuses when you get a meter hooked up. set your meter on amps and plug the positive probe at the meter into its 10 amp hole. Disconnect the negative cable and hook the leads between the cable and the battery. read the draw and start pulling fuses until you find the circuit that kills the draw. That will give you a direction to go
16 years 5 months ago #314 by bstevens
Thanks for everyones input. I will let you all know what I find.
