new situation
15 years 6 days ago #6940
by neilh
Replied by neilh on topic new situation
Just downloaded it fine here in Sunny Diego....
15 years 6 days ago #6941
Replied by 928mac on topic new situation
Thanks Neil, it is a network thing at work as I suspected.
whcherman must be having the same issue.
15 years 6 days ago #6942
by the flying scotsman
Correct.
I just double checked PET and it seems theres several variations of engines for the model year......can you confirm if the engine is 2 or 4 valve and how many distributors it has?
Brad....the issue is at ur end......dloaded in under 2 mins on a wireless connection but then again Im in the biz
Replied by the flying scotsman on topic new situation
whcherman;7094 wrote: thank you, that is what i was trying to understand. so when the belt is stationary or broken the distributor will not rotate. is that correct?
Correct.
15 years 6 days ago #6944
Replied by pcar928fan on topic new situation
Malcolm,
His car is an '84 US so it will have a single dist and be 4.7L in displacement and be a non-interference engine...
15 years 6 days ago #6945
ok....if thats confirmed the disti is gear driven from where?
if the camshaft, then theres still the probability that the cam belt has broke.
15 years 6 days ago #6946
Yes, the distributor is is gear driven by the 5-8 camshaft on a US 83-84 model 928S. As others have already stated, you have a 16 valve, 4.7L non interference engine. No bent valves. There is a peep hole on each timing belt cover beneath the long black plastic tubular intake plumbing. With the engine in the start position you should see the belt and sprockets revolving. If the belt is broken then all you are likely to see are the sprockets.
Replied by Kiln_Red on topic new situation
malcolm;7103 wrote: ok....if thats confirmed the disti is gear driven from where?
